Farmall Tractors Discussion Board
Farmall Cub rear main seal
Posted by p on August 17, 1999 at 15:21:17 from (209.186.155.29):
I just did a full overhaul of a '52 cub. The rear main seal fit really loose but I gave it a shot. It is now leaking... I should have known. the dealer says that the new one is rubber replacing an unavailable steal one, and therefore will require a new seal retainer. about $150. After all the dough I have spent does anyone know of a cheaper but effective repair. For instance would roughing up the retainer(peening it )allow for enough traction to hold the seal.
Post a Followup
: Re: Farmall Cub rear main seal
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
