Re: Year
Posted by RedTed/MO on July 27, 2002 at 19:45:22 from (63.71.128.124):
In Reply to: Year posted by Matt on July 27, 2002 at 18:39:46:
Matt:
Here's how to ID the year your tractor was assembled. The larger parts -- engine block, transmission housing, wheel castings, etc. -- will have a casting code that shows the day-month-year that the part was cast at the foundry. It'll look like a little plate, about the width of a popsicle stick, but only half as long, with a couple of screws; in fact, it's part of the casting. The day and month will be numbers. The year is a letter code, starting with "A" in 1931. So,... N=1944, and R=1948, and so forth. (V wasn't used, and both U and W were used in 1951).
See if you can find the codes -- they won't all be the same, but should be close -- and go from there.
RedTed/MO.
Post A Followup
: Re: Re: Year
