Re: Am I missing something
Posted by CraigMN on July 27, 2002 at 19:58:20 from (209.131.236.33):
In Reply to: Am I missing something posted by KillerRed on July 27, 2002 at 11:30:17:
Your observations of he Ammeter on the A Farmall is normal. You probably put a 55 or more amp alternator on it and your original amp gauge only goes to 20 amps. After starting the engine with the starter your alternator is recharging the battery. After the charge comes back up the gauge will return to near zero. You might want to instal a 30 amp ammeter and be sure you have heavy enough wire in the charging system. Your volt meter on the other tractor sounds like is operating normal too.
Post A Followup
: Re: Re: Am I missing something
