Re: F-20 HP RATING
Posted by Don LC on July 28, 2002 at 05:54:07 from (24.166.248.35):
In Reply to: F-20 HP RATING posted by grego on July 27, 2002 at 17:56:51:
NEBRASKA TRACTOR TEST ---Nebraska Agricultural Engineering Dept.devised the tests and the test equipment,whichhave since become standards for the world....the first completed tests were made inthe spring of 1920....Belt/PTO Horsepower,the max. horsepower developed at the belt pully or PTO....Drawbar HP.is based on max. drawbar pull and speed....The difference between PTO. and drawbar HP> is due to slippage and the power required to move the tractor......Pull in pounds was used to calculate HP.If you will go to RESERCH & INFO listed on the left side of thi page and click on Articals....Go down to Horsepower Defined, you can read in depth the information you want.....
Post A Followup
: Re: Re: F-20 HP RATING
