Re: Re: fifth gear lockout bolt?
Posted by Bob on July 28, 2002 at 07:19:54 from (166.102.96.45):
In Reply to: Re: fifth gear lockout bolt? posted by Dave on July 27, 2002 at 19:09:54:
Dave, I looked on the tranny cover and I don't see a bolt at one o'clock. Is it one of the bolts that hold the steering post on? One of the bolts that hold the rear gas tank support on? If I look straight up from the shifter there is a bolt. I took it out and when you look down the hole and try to shift it into fifth gear you can see something moving inside the hole. Nothing moves when you put it into any other gear just fifth, but it still will not go all the way into fifth. Thanks Bob
Post A Followup
: Re: Re: Re: fifth gear lockout bolt?
