Re: Seized Super A
Posted by George Steele on July 29, 2002 at 14:03:54 from (152.163.206.177):
In Reply to: Seized Super A posted by geoff gauger on July 29, 2002 at 10:17:57:
make sure the bushing oil hole linesn up with the distribution hole in the block. I think these are like a cam bearing and must be lined up with pressure hole to get lube to pinion.Good Luck
Post A Followup
: Re: Re: Seized Super A
