Float valve
Posted by Plant Doctor on July 29, 2002 at 15:15:43 from (209.204.122.74):
Am I the only one that continues to have problems with the float valves leaking? We have 4 Farmall AV's and 3 of them leak almost all of the time. All three have had the carbs rebuilt more than once. I thought maybe I forgot how install the float assembly, so I took the carb to the dealer and had them overhaul it. The results were the same. I have inline filters and sediment bowls, but still have problems. They don't flow gas out, but over time they drip just enough to either run down the side of the block or run into the oil in the air cleaner. Any solutions???
Post A Followup
: Re: Float valve
