Re: Re: 560 Farmall - running real bad
Posted by Matt Clark on July 31, 2002 at 13:05:28 from (209.64.158.18):
In Reply to: Re: 560 Farmall - running real bad posted by Walt on July 31, 2002 at 12:28:10:
Wow...5 turns? Had a buddy who was a tractor mechanic (many years ago) who told me 2 - 2 1/4 turns. Maybe his memory's slipping. I'll sure try that one first, as it's the easiest. It started doing this a few months ago, and got drastically worse this spring. Didn't run it much since Dec., when new clutch/pressure plate were installed (another story in itself).
One last question: It seems the high speed needle is awfully loose, with no spring to help hold it's position. That may be the issue - it just worked it's way out of adjustment - possible??
Thanks all, and I'll listen to any other suggestions. I'll also be sure to let you know what I figure out.
Post A Followup
: Re: Re: Re: 560 Farmall - running real bad
