Re: Re: Re: 560 Farmall - running real bad
Posted by K.B. on July 31, 2002 at 13:56:11 from (209.163.14.176):
In Reply to: Re: Re: 560 Farmall - running real bad posted by Matt Clark on July 31, 2002 at 07:41:21:
If ajusting the carb like the other guys said doesn't help, and you think the gas tank needs cleaning, I find the best way to do it is to remove it from the tractor (bolts aren't always frozen too bad). You can then put some heavy bolts or a length of chain in the tank and shake it around to knock the rust flakes/dirt loose and then pressure wash it out, or take it to a radiator shop and let them boil it out and seal it, but that can get a little pricey, or you can buy acid etch and sealer and seal it yourself. Whatever you decide to do, you can do a much better job with the tank out of the tractor.
Post A Followup
: Re: Re: Re: Re: 560 Farmall - running real bad
