Farmall Tractors Discussion Board
Re: F12 Stuck Rings?
Posted by Ed on August 17, 1999 at 20:55:51 from (205.188.193.39):
In Reply to: F12 Stuck Rings? posted by Jim Autry on August 17, 1999 at 14:36:59:
Try a little oil in each cylinder and then try cranking again. The oil will help seal up the rings a little. If the compression picks up then you probably do have stuck rings. If not, then the valves may not be seating. Try tapping on the end of the valve stems. If they are ok you should hear a good click when they pop up.Sometimes you can get a ring of rust on the valve stem that keeps it from going completly home. Good luck.
Post a Followup
: Re: Re: F12 Stuck Rings?
