Re: Manuals on McCormick No. 2 Subsoiler **Picture**
Posted by randy hall on August 01, 2002 at 20:32:30 from (209.11.236.80):
In Reply to: Manuals on McCormick No. 2 Subsoiler **Picture** posted by Aaron on August 01, 2002 at 16:08:10:
ih subsoilers must be a rare breed. i have one that is larger and heavier than the one in your picture. the tag says k s subsoiler and the serial number is p 1 it was built at the stockton works in california. it will go in the ground about three feet and it has a cast iron "worm" that hooks up behind the point. it will stand the front end of the 1466 up in the air in clay ground it must have been built to be pulled by a crawler.
Post A Followup
: Re: Re: Manuals on McCormick No. 2 Subsoiler **Picture**
