Re: Re: Re: farmall h 5th gear question?
Posted by Bob M on August 02, 2002 at 03:01:51 from (24.169.120.138):
In Reply to: Re: Re: farmall h 5th gear question? posted by Bob on August 01, 2002 at 16:52:20:
Bob - Try this: Remove the shift lever (drive out the 3/8" dia shift lever pivot pin just beneath the lever dust cover, then lift the lever free). Peer inside the opening and you will see the 3 shifter rails. Take a big screwdriver and engage the slot on the LEFT shifter rail. Now slide the rail as far forward as it will go. It should lightly "snap" into a detent at the end of it's travel. If the rail doesn't move easily, rock the tractor slightly or bump the starter until you feel it drop in. With the left shift rail in it's full forward position now try if 5th gear works. If it does the problem is a worn/bent lower end on the shift lever. It can usually be corrected by building up the bottom tip of the lever with weld, then grinding it back into shape. If 5th gear still doesn't work, problem's a worn direct (5th gear) sliding gear clutch or a worn 4-5 shift fork - time to pull the top of the tranny for a look inside. Good luck!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
