Re: Re: 140 radiator
Posted by john on August 02, 2002 at 04:35:21 from (12.32.235.251):
In Reply to: Re: 140 radiator posted by Hugh MacKay on July 30, 2002 at 17:00:58:
regarding the heater hose on 140, upon further investigation, the hose runs from the water pump on right side, back under frame and connects to the engine block where the lower radiator hose enters the block. It is hooked to a fitting that also has the drain petcock. If anybody has any ideas as to what this hose is for I look forward to hearing from you.
Post A Followup
: Re: Re: Re: 140 radiator
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
