farmall H valve adjustment
Posted by Ryan on August 02, 2002 at 14:33:17 from (209.143.11.81):
What is the proper valve tappet adjustment clearances for the exhaust and intake valves? this would be on a farmall H around a 1948. Could anyone advise the proper degrees timing on the flywheel for the distributor setting? Does anyone know the seal # on the pto shaft seal, a CR number etc? thank you.
Ryan
p.s I know I need a tech manual
Post A Followup
: Re: farmall H valve adjustment
