F-20 , 15-30 expert needed
Posted by Dave Houghton on August 02, 2002 at 14:54:32 from (12.82.70.24):
I need some crankshaft info from someone who has worked on both. How much larger end to end is the 15-30 crank? Would it fit in the f-20 crankcase, if the bearing and flywheel shaft area were machined to f-20 specs. I currently have the f-20 fitted with 4.625 pistons making it a 336 cid. Looking at alternative to cut and weld. Not to many old iron people on the pulling board.
Post A Followup
: Re: F-20 , 15-30 expert needed
