cub specs
Posted by Dan WV on August 02, 2002 at 15:06:14 from (68.112.47.194):
I need a little info for my cub.I replaced the rear engine seal and clutch disc and I need the torque specs for the flywheel bolts and the pressure plate retaining bolts. My IT manual is back ordered. Also, This may be a stupid question but is there anything for the release bearing to ride on on top of the input shaft or does it just float on the acuating arm without even touching the input shaft? Thanks in advance, Dan.
Post A Followup
: Re: cub specs
