Re: farmall h magneto
Posted by Diesel Don on August 02, 2002 at 21:32:01 from (206.40.118.76):
In Reply to: farmall h magneto posted by stan johnson on August 01, 2002 at 17:22:14:
Do everything these fine gentlemen have told you first.If you still have no spark,crank the engine by hand and listen for the impulse coupling to trip.If it does trip,my next guess would be a coil problem.If you don't hear it trip,there is a problem with the impulse coupling.You won't get a good spark at cranking speed without it working.If it does turn out that the impulse coupling is bad,e-mail me or post it on the forum.It may still be repairable.I'm in the process of repairing an H4 mag right now so maybe we can get you going.There are a couple more tests that can be done also but let's start with this.This will isolate the problem to mechanical or electrical.
Post A Followup
: Re: Re: farmall h magneto
