Re: Re: Re: M flywheel
Posted by The Red on August 04, 2002 at 08:48:36 from (12.84.239.165):
In Reply to: Re: Re: M flywheel posted by John (SC) on August 04, 2002 at 07:59:33:
I had an F20 that would jar your teeth when you engaged the clutch. The culprit was real bad wear on about 120 degrees of the metal pressure plate. It had been engaging crooked to the clutch plate and flywheel.
Post A Followup
: Re: Re: Re: Re: M flywheel
