Re: PTO for Farmall H
Posted by Leroy on August 04, 2002 at 12:38:00 from (65.56.5.5):
In Reply to: PTO for Farmall H posted by Jeffrey on January 20, 2002 at 18:21:22:
I also have a 1941 "H" and the PTO shaft started leaking oil. I removed the bolts that seem to hold the PTO in, but I couldn't get anything out. Did you replace the seal on yours? How difficult was it?
My tractor also uses a lot of oil. Is it most likely going by the rings or could it possibly be all going by the valve stems?
Thanks,
Leroy
Post A Followup
: Re: Re: PTO for Farmall H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
