Re: fan housing/farmall c
Posted by Haas on August 05, 2002 at 19:34:13 from (166.72.245.83):
In Reply to: fan housing/farmall c posted by steve on August 05, 2002 at 05:06:03:
I guess you are talking about the fan hub to which the fan is attached and that has the pulleys on it and a bearing inside. It has a screw plug to add oil. If this has been taken apart, there is an oil slinger inside that must be installed correctly. If put in backwards, oil will not circulate properly and the bearing will seize up. Also it does not take much oil. You put oil in through the hole where the screw is. then turn the fill hole down and let the excess drain. There is a little stand pipe in there to make it retain the correct amount. If in decent condition and all is assembled correctly and the oil level is correct, oil should not come out. Grease is suggested below. I don't think that will work, as the sleever bearing is not designed for grease. It's designed so that when turning, oil circulates through the bearing. Aftermarket replacement fan assemblies that have permanently lubricated ball bearings are available if you want to go that route. The original sleeve bearing will last and last if properly maintained. It'll still be going long after the "permanent" ball bearing with no way to renew the lubricant is gone.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
