Re: Farmall H with regulator problems
Posted by The Red on August 06, 2002 at 09:07:42 from (206.246.187.2):
In Reply to: Farmall H with regulator problems posted by Richard C on August 06, 2002 at 09:03:31:
Richard, that regulator should have either a screw adjustment for the points gap or a spring where you slightly bend the arm that the spring is attached to. In your case, you need less spring tension or adjust the gap on the points slightly smaller. Just make sure the points are opening when you shut down the tractor.
Post A Followup
: Re: Re: Farmall H with regulator problems
