Re: Diesel 400 distributor
Posted by Bob M on August 06, 2002 at 12:25:20 from (24.169.120.138):
In Reply to: Diesel 400 distributor posted by Alex on August 06, 2002 at 09:01:03:
Alex - I had a similar difficulties with an IHC pickup (304 V8). Problem turned out to be a badly worn distributor shaft bushing. It let the shaft wobble around inside the distributor which messed up the point gap and caused the timing to jump all over the place. That in turn caused the motor to start hard and run poorly. Rebushing the distributor and replacing the distributor shaft cleared it right up. Suggest removing the distributor rotor from your 400 and check to check for radial play in the distributor shaft. If you detect any play at all you likely have found the problem. Note - A broken spring in the advance could cause poor running too, but would not make the timing jump all over. Hope this helps...
Home
| Forums
Today's Featured Article -
Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
