Re: Steering on Super A
Posted by Haas on August 07, 2002 at 18:54:23 from (166.72.245.126):
In Reply to: Steering on Super A posted by Jan on August 07, 2002 at 18:26:59:
Lot's of posts in the archives on this common problem. Check all the tie rods for play in the joints. If any are loose, you may be able to tighten up with the adjusting screws in the ball sockets. Caution though, as the balls wear to an egg shape and if you get them tight when the steeing is centered, they may be so tight you can't turn all the way to the stops. Check the center steering arm to see that is it tight to the steering gear shaft. Sometimes the retainer nut works loose. It's hard to get to to tighten it up. You may have to remove the front axle to get a wrench on it. The shaft is tapered with a key. Sometimes the key slots wear and that causes play. Also check your steering shaft by jacking up the front end and pulling or pushing on the steering wheel. If you can move it in forward or back, the ball bearing on the worm gear is worn out. It's easy to replace by removing the big plug in the front of the steering gear and then screwing out the worm gear. The end of the shaft has a cotter key and a castle nut to hold the bearing on. These are about all you can do without removing the steering gear housing and doing a complete rebuild with new bearings on the worm wheel(sector gear) shaft, and possibly a new gear. New gears will be expensive, good used ones are hard to find. The steering shaft and the worm gear are all one piece. Hope this helps.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
