Re: Re: 300U Hydraulics Mystery - HELP!
Posted by Kilian on August 07, 2002 at 20:07:19 from (207.230.193.57):
In Reply to: Re: 300U Hydraulics Mystery - HELP! posted by joe on August 07, 2002 at 16:55:17:
Joe: What all is involved with rebuilding a control valve? Do you just replace the O-rings, or are there other parts that should be replaced.
I am also needing to rebuild the safety/flow control valve. Will a good cleaning and O-ring replacement be enough, or should I also order the service pack from Case/IH ($144, contains a gasket, seal, piston, and seat)?
Thanks for your help.
Post A Followup
: Re: Re: Re: 300U Hydraulics Mystery - HELP!
