Re: 300U Hydraulics Mystery - HELP!
Posted by dick on August 07, 2002 at 21:16:03 from (209.245.10.77):
In Reply to: 300U Hydraulics Mystery - HELP! posted by Bob Kirk on August 07, 2002 at 14:55:00:
It sounds to me as though you have a plug somewhere around the control valves for the loader (I assume the bucket doesn't rotate either?). With power steering, the pressure line should be external tubing with the loader's control valves mounted on the reservoir forward of the Fast Hitch control valve - if it's hooked up according to IH's original design. If not, your system isn't standard and you probably need to describe it further to get much help here.
Assuming the IH design, does the pump load up when you toggle either or both of the loader's control valves? If not, there's probably a plug in either the control line (smallest port joining to the loader control valves on the side of the reservoir - most likely) or in the return line from those control valves to the reservoir (not very likely).
As far as the oil leak goes, you need a new O-ring, but I don't think it has anything to do with the loader problems. The buzz may mean a short life-expectancy for your pump - hard to say.
Hope some of this is helpful. Repost if more input might be helpful.
Post A Followup
: Re: Re: 300U Hydraulics Mystery - HELP!
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
