Re: Belly Mower
Posted by Haas on August 08, 2002 at 10:20:51 from (166.72.245.23):
In Reply to: Belly Mower posted by Rick Gilliland on August 07, 2002 at 16:52:18:
The mower from the Super A should fit. However, anything for a Super A is usually designed to use the hydraulic lift that the Super has and the A does not. So you'll need to rig up some kind of a lift if you don't have a hand lift with a lever already.
Post A Followup
: Re: Re: Belly Mower
