Re: Re: Re: Need more torque
Posted by Deere Puller on August 09, 2002 at 05:02:10 from (156.77.100.117):
In Reply to: Re: Re: Need more torque posted by Farmall puller on August 08, 2002 at 20:31:19:
I'd take a look at your tire selection. You may benefit from dropping down to a 15.5 where you can get more psi directly on the ground. Those 18.4's have a larger contact patch & it really dilutes the weight distribution when you desparately need to get a bite. Those tires are good for hi-speed pulling or at heavy weight class such as 8500 & up. Been there with a friend & the move took a tractor that was typically mid-pack & turned it into a winnner / top 5 once switch was made. Good Luck
Post A Followup
: Re: Re: Re: Re: Need more torque
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
