Re: Oil leak what did I install wrong??????????
Posted by Dave_Id on August 09, 2002 at 06:09:14 from (67.250.102.237):
In Reply to: Oil leak what did I install wrong?????????? posted by Chad Penny on August 09, 2002 at 05:20:45:
I'd suspect you did something wrong.... I'm afraid if you started it up, it would dump out very rapidly. I'd also say it was the rear main, but it could be something else...won't be able to see until you got it pulled apart
Post A Followup
: Re: Re: Oil leak what did I install wrong??????????
