Re: Re: Re: 504 steering and hydraulics
Posted by Salvage Man on August 09, 2002 at 07:47:38 from (198.247.178.195):
In Reply to: Re: Re: 504 steering and hydraulics posted by JD Humm on August 08, 2002 at 14:40:14:
Have you checked the pump pressure? I check the pressure at the pump. Put a gauge in the test port on the pump plate. By putting the gauge here you can tell what the steering pressure is doing. Also this summer we had a 504 that had an upper u-joint that was binding up. Also check the bearing on the end of the worm shaft.
Post A Followup
: Re: Re: Re: Re: 504 steering and hydraulics
