Re: 1066 steering problem
Posted by Hugh MacKay on August 10, 2002 at 02:31:49 from (216.208.58.114):
In Reply to: 1066 steering problem posted by Randy on August 09, 2002 at 20:16:36:
Your problem must be in the steering controll just under dash. I bought a 1066 new, steering malfunctioned in first year, was a warrenty job, so dealer fixed on farm and that was where problem was. There really isn't much else that can go wrong, there is no mechanical linkage to front wheels. It doesn't sound as though it would be cylinder at front axle. On my tractor once that first little problem was fixed, it was trouble free for 10,000 hours.
The other item is pump, look at manual, steering pump is separate from main hydraulics. If I remember correctly there are 3 hydraulic pumps. The steering pump I believe has other functions on tractor, manual should tell you which ones, to see if they are working properly also. This may help you isolate where problem is.
Post A Followup
: Re: Re: 1066 steering problem
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
