Re: 1066 steering problem
Posted by Daniel on August 10, 2002 at 15:35:02 from (67.32.248.125):
In Reply to: 1066 steering problem posted by Randy on August 09, 2002 at 20:16:36:
I have a Farmall 806 with the same problem. It has been like this for about 4 years. It seems to have corrected itself for now, but I believe it may have been a sticking valve in the M.C.V. causing the pump to lose a prime, but I'm not sure. The only thing good about it is that no one else wants to use it. Good luck in finding the problem, I would like to know what you find.
Post A Followup
: Re: Re: 1066 steering problem
