Re: Thanks Bob M
Posted by Bob M on August 11, 2002 at 07:18:05 from (24.169.120.138):
In Reply to: Thanks Bob M posted by Gordon (Tx) on August 10, 2002 at 17:07:43:
Thanks for the kind words Gordon!
30 amps charge into a low battery is normal with an alternator. It may do this for 2 - 3 hours of running before the battery comes up all the way. However when the battery is full the ammeter should show only 2 - 4 amps of charge at governed RPM. Any higher than this will overcharge and eventually ruin the battery.
If you have an accurate DC voltmeter, take a reading directly across the battery with the motor running at at governed speed. If meter reads less then 14.5 volts or so, everything is fine. If it shows >15 volts, you are overcharging.
Post A Followup
: Re: Re: Thanks Bob M
