Re: wife needs help with H gas problem FAST!!!
Posted by Justin on August 11, 2002 at 11:57:39 from (12.30.224.211):
In Reply to: wife needs help with H gas problem FAST!!! posted by Becky on August 11, 2002 at 11:42:08:
Becky,
It sounds like the float in the carb. is sticking to me!Quick fix 9 out of 10 times= take the handle of a screw driver and smack the carb a few times not to hard but hard enough to let it know ya mean business!Make sure gas is on when ya do this and see if it stops.If no luck try 1 more thing shut gas off,Remove square head set screw on bottom of float bowl( on carb) let excess gas drain out and spray carb.cleaner up in the float bowl assembley let excess cleaner run out,reinstall set screw and turn gas back on.I hope it helps.
Justin
Post A Followup
: Re: Re: wife needs help with H gas problem FAST!!!
