Re: Rear axles of Super A
Posted by Blll Hires on August 11, 2002 at 13:24:08 from (128.206.26.250):
In Reply to: Rear axles of Super A posted by Belinda on August 11, 2002 at 08:27:28:
The rear axle, has a cap screw through a washer, threaded into the end of the axle. A bearing and spacer are behind this washer. This assembly is protected by a pressed steel bearing cap held on the bull gear housing by small cap screws.
Post A Followup
: Re: Re: Rear axles of Super A
