Re: fixin' to set fire to Cub
Posted by BIG JOHN on August 11, 2002 at 15:27:30 from (205.188.200.146):
In Reply to: fixin' to set fire to Cub posted by mgb on August 10, 2002 at 20:32:36:
Many engines will surge in RPM's just as they run out of gas. Next time it shuts down quickly pull the plug from the bottom of the carb and see if you have a full flow of fuel. Once found that I had a tree leaf in the gas tank that would float over the outlet sometimes. Couldn't believe it.
Post A Followup
: Re: Re: fixin' to set fire to Cub
