Re: Rough running f-12
Posted by Bob Kerr on August 11, 2002 at 17:56:20 from (205.188.193.26):
In Reply to: Rough running f-12 posted by shank on August 11, 2002 at 14:59:20:
If carb adjustments don't do much I would check the carb out good or just rebuild it. float level may be too high or needle valve may be leaking. My f-12 if the tank is filled all the way will run very rich and flood easy when starting, it runs fine when gas level is below the fuel bowl level on the carb. The needle valve on mine is leaking.
Post A Followup
: Re: Re: Rough running f-12
