Re: 504 Transmission, Clutch issues?
Posted by Owen Aaland on March 27, 2009 at 14:57:50 from (65.165.246.54):
In Reply to: 504 Transmission, Clutch issues? posted by tonyaandralph on March 27, 2009 at 12:20:42:
Sudden failures like that are most likely either the spring damper assembly in the clutch disk or the splined coupler in front of the TA clutch. If you take the stamped steel cover off (four bolts) on the top center of the clutch housing you should be able to see the coupler.
