Re: Super A loses hydraulic fluid - - - You Guys Were Right! - - -
Posted by Glenn(WV) on August 12, 2002 at 05:30:41 from (166.123.208.114):
In Reply to: Super A loses hydraulic fluid - - - You Guys Were Right! - - - posted by David Stubbs on August 11, 2002 at 19:13:10:
I'd replace both the pump seal ring and gasket just to be on the safe side.
Glad to hear that you found out where it was going!
Post A Followup
: Re: Re: Super A loses hydraulic fluid - - - You Guys Were Right! - - -
