Re: Fast-Hitch Spacers
Posted by Keith Schuler on August 12, 2002 at 12:07:16 from (47.230.0.42):
In Reply to: Fast-Hitch Spacers posted by SuperCmore on August 09, 2002 at 06:14:53:
If the others dimensions don't work, let me know and I will measure mine. There is a hole drilled in them as one of the others mentioned. There is a hole in your 2 point socket also. You can pin these shims in place to use the smaller equipment all the time. Since I have both sizes of equipment, I just leave them loose in there and remove them when I want to use equipment with the larger prongs. 1/2" X 1" X 13" sounds about right though.
Post A Followup
: Re: Re: Fast-Hitch Spacers
