Re: Farmall A cracked block. Should I bother?
Posted by Phil Auten (Tx) on August 12, 2002 at 13:19:40 from (63.173.243.163):
In Reply to: Farmall A cracked block. Should I bother? posted by Scott McConaghy on August 12, 2002 at 13:05:58:
Scott,
As long as the crack is just in the outer part of the water jacket it can be repaired with J-B Weld. I have seen several repaired in this manner including one that was so bad I believed that it was not salvagable. That tractor runs fine and does not leak, but it is restricted to show and parade duty. Repair it. It's a lot less expensive and a lot less work.
My 2¢,
Phil
Post A Followup
: Re: Re: Farmall A cracked block. Should I bother?
