Re: Will wide front from Super C fit on an H?
Posted by JD Humm on August 12, 2002 at 17:59:25 from (64.159.123.97):
In Reply to: Will wide front from Super C fit on an H? posted by Boondockjones on August 12, 2002 at 17:13:15:
We have two SC's with wide fronts and in my opinion you would not be happy with one on an H, I am sure it could be adapted to fit, if not a direct fit. That front axle is pretty light, the front end on the first tractor was all welded and cobbled up, I spent hours rebuilding it, copied it piece for piece. If it breaks up that bad on a SC, I can only imagine what a larger, heavier H would do to it. Of course this tractor had been abused a good portion of it's life but now it is spoiled! So I am sure care is a good part of how it would hold up as well.
Post A Followup
: Re: Re: Will wide front from Super C fit on an H?
