Re: Re: Re: Re: Re: Re: Re: Re: 12 volt Alternator
Posted by Don LC on August 12, 2002 at 21:10:05 from (24.166.248.35):
In Reply to: Re: Re: Re: Re: Re: Re: Re: 12 volt Alternator posted by Doug in OR on August 12, 2002 at 16:07:27:
I got my pully at "GRANGER" it is 1 1/2"x1/2"belt size x5/8" bore,no key way,just a set screw ....I don't understand why nobody is telling that you must bore the 5/8" bore out to fit the alternator shaft-- .669" or 17MM....I had to cut the face where the set screw is down so I could use the nut....leave the spacer out....By the way Granger's pully is steal...every thing else I found was 1 3/4" Alum......
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: 12 volt Alternator
