Re: head numbers??
Posted by RPM on August 13, 2002 at 07:04:39 from (63.110.182.225):
In Reply to: head numbers?? posted by mpuller on August 12, 2002 at 19:59:39:
There were a lot of different heads, main casting numbers for gasoline were 8060D-, 8574D-, no M had LPG option, Super M had LPG option, used same gas head 8574D-, 400/450 LPG option had a head unique to them, 364586R1 higher compression with special part number valves, all used the same head gasket, last heads made by IH to retrofit M/SM were gas 450 parts, 362433R1 casting number, this were furnished complete to fit older tractors, part number 70011C91, valves, springs all assembled for use on gas tractors, you will find old heads with other casting numbers for kerosene, distillate, also valves + springs were different on these.
Post A Followup
: Re: Re: head numbers??
