Re: Re: Leaky carb fitting
Posted by Gramps on August 13, 2002 at 13:55:02 from (64.105.216.218):
In Reply to: Re: Leaky carb fitting posted by RPM on August 09, 2002 at 06:16:17:
I have a stright thread brass fitting. Mine is a gear drive.
I have read that you can use JB weld with silcone on the treads to repair the stripped treads. I will give it a try. Thanks for the responses.
Post A Followup
: Re: Re: Re: Leaky carb fitting
