Re: Tires Rims for a Farmall A
Posted by Hugh MacKay on August 13, 2002 at 16:46:18 from (64.228.11.164):
In Reply to: Tires Rims for a Farmall A posted by Rich on August 13, 2002 at 16:31:19:
Most SAs have 8" rims with 9.5 x 24 tires. I think the 7" rim was standard on Cub. What you are doing will work fine on hard ground. SA will be quite heavy and make marks on soft ground. With 9.5 tires SA is probably one of the heaviest ground bearing tractors going in pounds per square inch. This is precisely why the SA has such good traction.
Post A Followup
: Re: Re: Tires Rims for a Farmall A
