Re: Chattering voltage and ammeter
Posted by Bob M on August 13, 2002 at 18:48:43 from (24.169.120.138):
In Reply to: Chattering voltage and ammeter posted by BEL @IN on August 13, 2002 at 18:05:47:
Ben - A bad ground at the voltage regulator can cause that. Try running a ground wire directly from the regulator base to the grounded battery cable and see if that cures it.
Post A Followup
: Re: Re: Chattering voltage and ammeter
