Farmall Tractors Discussion Board
Re: Super A rear wheel seals.
Posted by Roger on August 18, 1999 at 20:07:06 from (209.100.170.94):
In Reply to: Super A rear wheel seals. posted by Rich Benson on August 16, 1999 at 22:24:51:
What Daniel says is correct, but you will still need to press the bearing off the axle to get at the seal. I had to take mine to a shop to have it pressed off. Roger
Post a Followup
: Re: Re: Super A rear wheel seals.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
