Re: Re: Re: Re: Re: Re: 1 Wire Alternator?
Posted by Bob M on August 14, 2002 at 11:46:01 from (165.170.128.66):
In Reply to: Re: Re: Re: Re: Re: 1 Wire Alternator? posted by jmyt_47 on August 14, 2002 at 11:30:32:
Multimeter tests for you.... 1 - Battery drain: Make sure the lights and ign switch are off. Set the multimeter to read DC amps. Now remove the battery ground cable and connect the black meter lead to the battery post and the red lead to a good ground (can use the grounded cable terminal). Begin with the highest amp switch setting on the multimeter, then work down a step at a time until you get an indication. If the meter shows about 10 milliamps or less, that's fine. A higher reading means there's a current drain somewhere, most likely in the alternator. If it goes to 0 when you disconnect the wire from the alternator BAT terminal, the alternator is the drain. IMPORTANT!! DO NOT turn on any electrical loads (lights, ignition) or hit the starter while performing this test or you will destroy your meter! 2 - Running voltage reading: Set your meter to DC volts and measure the voltage directly across the battery terminals with the motor running at 1/2 speed. 13.8 - 14.5 volts is normal. Less voltage means the alternator is not charging fully, and more means the battery is being overcharged.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
