Re: Farmall H wont charge. Could it be a ground problem?
Posted by Bob M on August 14, 2002 at 12:13:53 from (165.170.128.66):
In Reply to: Farmall H wont charge. Could it be a ground problem? posted by atw on August 14, 2002 at 10:06:36:
What the former owner should have said is the ammeter BOX must be solidly grounded for the system to work. Try running a temporary ground wire from the light switch mounting bushing nut (the nut behind the knob) to the grounded battery terminal. If that solves the problem, either install a permanant ground wire here, or else clean to bare metal the mating surfaces between the light switch and the ammeter box cover, between the cover and the box, between the box and the steering post, and between the steering post and the tranny cover.
Post A Followup
: Re: Re: Farmall H wont charge. Could it be a ground problem?
