Re: Re: Old Raceway M Update-ENGINE IS LOOSE
Posted by billv on August 15, 2002 at 06:49:34 from (65.142.143.5):
In Reply to: Re: Old Raceway M Update-ENGINE IS LOOSE posted by Jim in Michigan on August 15, 2002 at 06:20:37:
There are two easy ways to tell the differece between a C and a Super C. One is the seriel number tag will say FC for a C, or FSC for a Super C. If the tag is missing or if the engine has been changed witch I have seen before where a C chasis has a Super C block are two casting marks on the block itself. A Super C has a casting mark on each side of the block. One of them is right under the carb. It will be a small rectangular bump and the other one is on the opposit side in about the same place.
Post A Followup
: Re: Re: Re: Old Raceway M Update-ENGINE IS LOOSE
